softer clutch
kennebecgtr
softer clutch
Post by kennebecgtr » Mon Dec 21, 2015 2:43 pm
Can I install a softer clutch on a 1967 305 scrambler? I have Carpal tunnel in my left wrist; so I can only handle approx. 20 minutes of shifting my CL77. Any advice on this subject? Thanks, William in Minneapolis.
Hamamatsu Nippon
Post by Hamamatsu Nippon » Mon Dec 21, 2015 3:56 pm
1967 CA78
1965 CM90
Soichiro Honda
OldStan
Re: softer clutch
Post by OldStan » Tue Dec 22, 2015 7:30 pm
kennebecgtr wrote:Can I install a softer clutch on a 1967 305 scrambler? I have Carpal tunnel in my left wrist; so I can only handle approx. 20 minutes of shifting my CL77. Any advice on this subject? Thanks, William in Minneapolis.
Some of the older 305's had weaker springs, but that went along with clutch slippage problems. I was having problems with my 67 scrambler clutch getting hard. check your cable routing, the larger the radius on the bends the better, lube the cable and it can make a huge difference.
63 CA78
stratone
+1
Post by stratone » Tue Dec 22, 2015 9:44 pm
I agree with Stan, once I routed my cable correctly and LUBED IT, it worked fine. It'll never be as smooth as newer bikes, but it is a lot better than when I got it.
Post by LOUD MOUSE » Thu Dec 24, 2015 7:26 am
A little less money. .............lm
eBay item number:
121759890029
Hamamatsu Nippon wrote:Here's what you need instead.
http://www.ebay.com/itm/Moose-ATV-Dirtb ... 1759890029
Hamamatsu Nippon
Post by Hamamatsu Nippon » Thu Dec 24, 2015 3:52 pm
I think you guys are misdiagnosing your patient. His chief complaint is carpal tunnel syndrome not sqeaky cable disease. He doesn't need oil/rerouting of his cables, he needs assisted leverage to aid in his disability. Sure oil your cables, but these easy pull systems really work. I knew a gal with arthritis who kept riding after she installed these easy pull levers.
1967 CA78
1965 CM90
Soichiro Honda
Post by LOUD MOUSE » Thu Dec 24, 2015 4:19 pm
OK!
So what is your cure? .................lm
Hamamatsu Nippon wrote:I think you guys are misdiagnosing your patient. His chief complaint is carpal tunnel syndrome not sqeaky cable disease. He doesn't need oil/rerouting of his cables, he needs assisted leverage to aid in his disability. Sure oil your cables, but these easy pull systems really work. I knew a gal with arthritis who kept riding after she installed these easy pull levers.
