Post
by Sascha » Tue Dec 07, 2010 10:39 pm
So, I got it off, mounted the bracket and put the side cover back on...
then I losened the bolt below the giant screw, turned the screw to the right until it locked, then I tightened the bolt to secure the position of the giant bolt... I added length to both the lever and to the part that goes in the motor, put it into first, and still the same problem... Its not allowing me to clutch in when I roll back and forth with the clutch in (in 1st gear).
Help!?
See pics...
Im wondering if the clutch lever inside the casing how to be mounted in a particular way!? I just put it back in on the rod... thats all, was I supossed to ensure it was on something else? I guess im starting to question whats wrong here.
