At times I get a feeling that there are those on the forum who Can/do cause confusion when offering "To Many Possibilities for a Simple Problem".
This is one of those.
Squeak/Squeal motor Seizure were/are the Keys from the start.
Pistons/cylinders were/are good and never the problem when shown early in this thread.
I admit that it Could Have Been something loose in the clutch side!
Been There Seen That!
Broken area of the case Could Have Been the problem if that small part was inside and rubbing the chain/clutch outer case.
Only saw one combustion chamber so wasn't able to compare the other exhaust valve to the one shown.
Yes, most exhaust valves show white when engine is adjusted correctly.
So the valve/missing piece diverted us from the area where "Not Common/Not Rare problem was.
As for the case I'd use it AS IS cause the damage was done in a way which won't/doesn't cause any oil flow/mechanical problem when the shaft is installed.
Just rambling comments from a Old Bike Rider/Runner who really tries to notice the Word Clues offered with the problem description.
Still No Answer as to How Do Ya Tighten The Nut on the Left Side of the CRANK!!!!!!!!!!!. ......lm
waynew wrote:AN UPDATE...LOUD MOUSE hit the nail on the proverbial head. I did have ALL 3 screws in the outer starting clutch to become loose and create the bind. Also one spring and cap fell out of the same part. The other issue i found on the left crankcase side concerning where the oil filter shaft meets the crancase appears to be an old break and i also could not find the broken piece anywhere. I want to thank everyone of you for your suggestions and support-it means alot. BTW, can any of you recommend anyone who rebuilds/repairs the tachometer and speedometer? Have a great weekend everyone!
