the weathered engine teardown
real_psyence
Post by real_psyence » Thu Aug 05, 2010 3:24 pm
This is a thread to document the teardown of a really corroded CB77 engine. If I get it all apart, and maybe find a donor engine, there will be a thread on the rebuild.
Basically, a cautionary tale of how bad it can get - I know there are worse, but this one is mine ;-)
Here goes.
As I got it:
The intake valve covers, crankcase side covers, cam tensioner, sparkplugs, left camshaft endcap/tach cable, and top engine cover had already been taken off.
I got the right cam end cap/cover off with a rubber mallet and some wiggling:
The bearing had frozen to the shaft.
After excavating and removing the two nuts holding the head to the cylinders, I was ready to take off the top end.
Unfortunately, easier said than done. Keep in mind, I had sprayed the entire engine with Freeze-Off (compare to Kroil, PB-Blaster, etc.) a couple days ago, including copious amounts in the top end and sparkplug holes. Some light persuasion with the mallet and a bunch of wiggling and fighting later, it came up off the studs:
A little rusty and corroded, but the valves look intact - not too bad...
What about the cylinders?
Houston, we have a problem.
I'll be taking a shop-vac to it later to remove the free rust, trying to clean it up a little before applying more penetrating oil. Looks like that trick with the gear puller might be warranted.
Hope you're either enjoying this or grimacing! More to come...
Gunner_CAF
Post by Gunner_CAF » Thu Aug 05, 2010 6:47 pm
Wow, what a mess. You sure this wasn't stored in the hold of the Titanic??
Good luck!
Gunner
big-b
Post by big-b » Thu Aug 19, 2010 3:05 pm
Wow, thanks for posting this, i feel a lot better about mine now. I also stumbled onto a superhawk for little money that needs a lot of work. Mine is frozen too but hopefully it doesn't look quite that bad once i get it apart. I'm just getting into it now. Motor is frozen and i haven't been able to locate the cam chain master link. I have the tensioner off and the oil pump. I'm hoping a better light and a little mirror might help me figure it out. I'd rather ot cut it yet.
Brian
mike1969
weathered engine
Post by mike1969 » Thu Aug 19, 2010 3:33 pm
Brian, If the engine has never been apart it won't have a master link.
I used a Dremel cut off wheel to remove the link. You'll have to buy a master link.
brewsky
Post by brewsky » Thu Aug 19, 2010 6:25 pm
Wow!, looks like the insides of my 51 DeSoto...
Might want to look at this link on penetrating oil...looks like you may have the perfect candidate to try it out.
http://forums.sohc4.net/index.php?topic=20131.0
big-b
Post by big-b » Thu Aug 19, 2010 8:45 pm
Thanks Mike 1969, that will save me some time.
Brian
nc_rider
Post by nc_rider » Thu Aug 19, 2010 9:47 pm
holy cow... yeah, I feel a lot better about the superhawk engine I have.
-- hey, those rims in the box ... are they for the cb77, and if so, where did they come from?
