CB77 Front brake setup, stopping is a good thing.
fallingpines305
Post by fallingpines305 » Tue Apr 22, 2008 6:32 pm
While my front wheel is off, I was planning on getting my front drum brake set up properly. I had this apart years ago and all is clean and the shoes are good, however I never liked it much when I pulled the lever and it would continue pulling almost to the the bar well after the brakes were engaged. I think that I may have one of the levers on the wrong spline and as a result one shoe is contacting before the other. It's a little difficult to look inside the drum when it's all assembled to know for sure.
Is there a procedure to ensure that the levers are on the correct location on the brake cam spline and the adjuster rod between them is set up correctly?
Post by davomoto » Wed Apr 23, 2008 4:35 pm
there should be small punch marks on the brake arms, and the splines. These line up on both arms. What I do then is raise the front wheel so I can spin it. Tighten up cable barrel at brake hub until brakes drag. I then adjust the rod between arm until it stops dragging. I repeat this process untill the shoes are centered, and then adjust slack into cable. Hope this helps!
fallingpines305
Post by fallingpines305 » Wed Apr 23, 2008 8:03 pm
davomoto,
Yes indeed there are punch marks to line up, very subtle on the spline ends and overlooked some time ago when I remember having rushed final assembly when I was in my 20's and knew everything. Anyhow, all good now and much better feel thank you. a far cry from good discs, however way better than the drum on my old BMW.
Thanks again,
Pat
Post by davomoto » Thu Apr 24, 2008 3:47 pm
Pat, glad it worked out, and you are very welcome!
