1967 cl77
redryder67
1967 cl77
Post by redryder67 » Sat Jan 12, 2019 8:09 pm
Just restored a '67 CL 77
Have a question. Why is the carb float bowel drain plug cross drilled?
Re: 1967 cl77
Post by G-Man » Sun Jan 13, 2019 3:20 am
Hi
Wlecone to the Forum!
I think it is cross drilled so that you don't have to take the screw completey out to drain the carb.
redryder67 wrote:Just restored a '67 CL 77
DJM
CL77 carbs
Post by DJM » Sun Jan 13, 2019 1:32 pm
As G Man says they are drilled so that you only have to loosen them but not take them right out to drain the float bowls.
If you ever drop the drain plug out of the LHS carb on your CL77 you'll be glad that they are made that way.
redryder67
thanks!
Post by redryder67 » Sun Jan 13, 2019 3:32 pm
thanks , I appreciate the feedback. Both cross drills were completely gummed up so I cleaned them out. Now to see if they leak. might need new gaskets, these are only 52 yr old. Ha HA
I am lovin this 67. It was my first bike in 1967 and Ive been collecting parts and fiddling with it for 10 years.Now its a ground up full restoration. All parts are OEM except battery, tires, and vinyl on the seat cover. Carbs were Ultrasounded but I guess these drain plugs didnt get cleaned out. Appreciate your feed back and glad I found this site,
"You meet the nicest people on a Honda"
thanks.
