Setting up aCA77
heliwilly
Setting up aCA77
Post by heliwilly » Tue Oct 23, 2018 12:25 pm
My brother has had a lot of work done on the CA77 he acquired.
The engine seems fine, but there seems to be a problem with the kickstart. When he kicks it over and the kickstart returns, there doesn't seem to be a stop that stops the kickstart in a specific place. What is the mechanism that is used as a stop when the kickstart returns under the pressure of the spring.
Thanks Bill W.
Re: Setting up aCA77
Post by LOUD MOUSE » Tue Oct 23, 2018 8:47 pm
It has to do with the location of the KS Shaft when the cover is installed.
Where are you located?. .....................lm
heliwilly wrote:My brother has had a lot of work done on the CA77 he acquired.
Thanks Bill W.
heliwilly
Post by heliwilly » Wed Oct 24, 2018 2:46 am
Hi LOUD MOUSE,
Unfortunately the bike is located in the UK near Leeds. Any written instructions would be very useful. Bill W.
Post by G-Man » Wed Oct 24, 2018 5:53 am
Bill
There is a stop in the clutch side of the kickstarter shaft. With the right side cover off, turn the kickstart shaft clockwise until it won't turn any more. It is now at the stop which 'parks' the ratched / pawl.
Then, replace the whole left side cover, with the spring tensioned. You should be fine.
Thanks Bill W.
Post by LOUD MOUSE » Wed Oct 24, 2018 7:48 am
Thanks G. (LEFT SIDE COVER?)
That's exactly what I would have said if he had responded to my message. .............lm
G-Man wrote:Bill
Thanks Bill W.
heliwilly
Post by heliwilly » Wed Oct 24, 2018 11:22 am
Thanks for the information G-Man.
I have been in contact with my brother who tells me, that with the rightside cover removed, the kickstart shaft can be turned clockwise continously, it doesn't stop. Is there some kind of a stop built in that stops the kickstart shaft tuning?
Do you have any drawings or diagrams that would show this stop.
Thanks for your help so far. Bill W.
LOUD MOUSE.
You asked my location, which I gave you 3 hours before G-Man replied. Bill W/
Post by LOUD MOUSE » Wed Oct 24, 2018 11:38 am
I also sent this with that message and expected a reply as to How/What so I could answer your reply.
The Shaft is stopped by a Large Bolt sort of thing (black, kick stopper bolt) installed in the lower case behind the outer clutch basket. .................................lm
heliwilly wrote:Thanks for the information G-Man.
LOUD MOUSE.
