Compression Ratio vs PSI
Vince Lupo
Post by Vince Lupo » Tue Sep 26, 2017 2:01 pm
I finally got the bike back and it's running like a charm. My mechanic mentioned that compression in the cylinders is 185 (left) and 190 (right). I read online that the way to calculate compression ratio is to divide the psi by the atmospheric pressure (14.7). Is that correct? If so, looks like I have between 12.6:1 and 13:1?
BTW what was the stock psi/compression ratio on the CB77?
cknight
Post by cknight » Tue Sep 26, 2017 4:15 pm
The cranking pressure is a result of the static compression ratio and the intake valve's closing point (along with the valve and ring sealing quality, stroke, rod length, atmospheric pressure, etc.). You can have a 14:1 static compression ratio racing engine with a late closing intake, or an 8:1 street engine with a very mild cam, and they both could pump 185 PSI. No direct correlation. Published figures show 9.5:1 compression ratio for the earlier pre-1965 CB77's, and 8.5-8.7:1 for the later ones. My 358cc Bore Tech engine also happens to pump 185 to 190 PSI with stock cams. Regards, Chase
Merz64cb77
compression
Post by Merz64cb77 » Tue Sep 26, 2017 4:19 pm
Hi Vince
Glad to hear that you got the bike up and running. As for the way to calculate the compression ratio I don't think it's that simple. The ratio of V1/V2 is based on the difference in volume between BDC and TDC.
I checked my manual and the stock compression pressure is 149.34 psi and a compression ratio of 9.3 to 9.7.
Merz
67' CB77
66’ CB77
65’ bomber
68’ hellcat
