Proper Kick Start Assembly--Seeking 100% Clarity
GregMcN
Post by GregMcN » Wed Aug 16, 2017 1:04 pm
Hi LM
Engine is not siezed, it will turn over fine on the rotor bolt. It will just not turn on the kickstart. ( I am kicking it the right way).
So looks like I will have to strip down. Can you split the crankcase without removal of barrel/ head?
Greg
Post by G-Man » Wed Aug 16, 2017 2:08 pm
Yep. Turn the thing upside-down and you can just take off the bottom cover. Don't forget the two studs in the 'valley'. The clutch and gear selector have to come off.
GregMcN wrote:Hi LM
Greg
Post by G-Man » Wed Aug 16, 2017 2:09 pm
GregMcN wrote:Hi LM
Greg
Post by LOUD MOUSE » Wed Aug 16, 2017 4:56 pm
Put the trans in neutral to prove if the clutch is stuck. .......lm
GregMcN wrote:Hi LM
Greg
GregMcN
Post by GregMcN » Thu Aug 17, 2017 4:12 am
Thanks LM,
I did put it in neutral but gear selection also seems difficult so I will check again when I take the clutch out.
Greg
GregMcN
Thanks LM,
Greg
GregMcN
Thanks LM,
Greg
