Oil Filter Servicing CA77
Re: Oil filter spinner chain installation, ideas?
Post by LOUD MOUSE » Tue Mar 21, 2017 3:59 pm
Call me.
I have a simple solution. ............lm
texasgrape wrote:I have been working for hours trying to get the chain back on w/spinner. I read the tips below by 48lesco, seems easy enough but that chain has the best of me. Clutch cover is the next option, but trying not to go that route. Ideas? Guess I can just keep plugging away, but thought someone may have a helpful hint.
NOTE: I have been putting the chain on inside gear first, then trying to lift up chain w/wire to put on spinner w/per step 8 below. Thanks! BTW, filter did its job, horribly dirty, so glad I checked it; I guess the PO never did. Thanks.
48lesco wrote:It's just a simple 10-step process...
1) Remove the three cover screws with an impact driver. The one at 6-o'clock can be... troublesome.
2) There's 2 slots for screwdrivers that allow you to start to jiggle-pry the round cover plate off. If you have the late version, the hole in the clutch cover is large and you can take everything out and put it all back together without removing anything else.
3) Remove the shaft, washer, centrifugal filter and chain or the chain can stay on the crank sprocket. There's a small radial pin on the end of the shaft, sometimes it's loose, usually not. Leave it in there.
4) Remove the snap ring, then with a wooden dowel, pound the centrifugal oil filter cover off from behind through the hole that the shaft goes through. Slowly but surely going around the outer circumference.
5) Clean everything out. There's usually a layer of soft material on the inside of the spinner that you can scrape out. How clean you get it depends on your personality.
6) Reassemble. There is a thin o-ring on the spinner cover that you should try to reuse. If not, Ohio Cycle. Make sure the snap ring seats fully in its groove. Sometimes a little light pressure in a vise helps to fully reveal the groove.
7) Put the washer on the shaft and the shaft into the spinner so that the washer is between the little radial pin and the spinner cover.
8) Get yourself some wire and bend up a hook that you can use to loop the chain around the back side of the spinner on to its sprocket as you hold the spinner by the shaft with your other hand. This is easier for left-handed people and you have to do it once yourself, it cannot be explained further.
9) Once the chain is on, fully insert the shaft through the filter into the engine case. Rotate the shaft so the radial pin is at 12-o'clock. Look at the back of the cover plate to see why.
10) Replace the cover plate with the 2 o-rings. One is available from Honda, the other Ohio Cycle. Don't be a hero tightening those screws up, I've never seen one come loose.
11) If you have an early clutch cover with the small hole. Just take off the whole clutch cover. The process is similar.
texasgrape
Post by texasgrape » Tue Mar 21, 2017 5:39 pm
I got it! Took a break and went back to it. I did have to rebend my wire more of a 180 degree bend. Took the bike for its first real ride down these country roads. Riding this bike is like going back in time. Can't think of one thing the Dream needs mechanically, runs great! Thanks Ed for all your help w/carb and cam chain adjuster and many other questions I had. I'm sure I'll have more down the road. Dana
Post by LOUD MOUSE » Tue Mar 21, 2017 6:01 pm
I lift it over the crank sprocket. ................lm
Good deal.
I use a dry chop stick (wood) to lift the chain onto the sprocket !. .....................lm
texasgrape wrote:I got it! Took a break and went back to it. I did have to rebend my wire more of a 180 degree bend. Took the bike for its first real ride down these country roads. Riding this bike is like going back in time. Can't think of one thing the Dream needs mechanically, runs great! Thanks Ed for all your help w/carb and cam chain adjuster and many other questions I had. I'm sure I'll have more down the road. Dana
texasgrape
Post by texasgrape » Tue Mar 21, 2017 10:03 pm
Good idea! I will do that at next oil change. Chopsticks should give more control! I'm doing an oil flush and curious how much grime the spinner will catch. Bike sat up for 35 years inside. PS I tried a telescoping magnet but it didn't work.
texasgrape
Post by texasgrape » Wed Mar 22, 2017 4:22 pm
LM, just to be clear for me and for others: You put the chain on the spinner first, insert shaft in it's hole, THEN lift chain up onto the crank sprocket? Thanks!
Post by LOUD MOUSE » Wed Mar 22, 2017 6:11 pm
The shaft installs into the case once the chain is on the crank sprocket. .............lm
texasgrape wrote:LM, just to be clear for me and for others: You put the chain on the spinner first, insert shaft in it's hole, THEN lift chain up onto the crank sprocket? Thanks!
antgat15
CA77 oil filter service
Post by antgat15 » Mon Feb 25, 2019 9:55 am
Good Morning
You will find a great video on how to easily service the oil filter. Hope it helps
https://youtu.be/eA1aBTGWZUs
