Dick Eastman
Post by Dick Eastman » Mon Dec 12, 2016 1:05 pm
jensey wrote:Hi,
Nice vacuum ports. I placed them to the inside instead of outside. This way they are hard to see when looking at the bike. I also make them on my CB450's, also pointed inwards.
It saves a lot of hassle, especially on the early 450's (the carbs are known as very sensitive).
Very nice build anyway !
Thanks - I don't mind seeing them, I like easy access. I used the oil manometer on my Kawasaki ZRX 1200 R, it had CV carbs on it, too, but they were not too sensitive - worked well.
Dick Eastman
Post by Dick Eastman » Mon Dec 12, 2016 1:20 pm
I did some plating yesterday [brake parts]; also made a front wheel collar and some swing arm pivot bolt washers, S/S; got the sprocket on, but the cover plate was warped, so I had to add some button screws to it.
My K&N filters arrived today - ordered them direct from mfr., p/n RC 0790. The tech at K&N said they will flow 100cfm each. I will oil them when ready to put in service.
engine build 001 (Medium).jpg (69.27 KiB) Viewed 5899 times
engine build 002 (Medium).jpg (70.79 KiB) Viewed 5899 times
engine build 004 (Medium).jpg (82.41 KiB) Viewed 5899 times
engine build 003 (Medium).jpg (69.95 KiB) Viewed 5899 times
engine build 006 (Medium).jpg (70.82 KiB) Viewed 5899 times
Post by Seadog » Mon Dec 12, 2016 1:30 pm
Looking great. Can't wait to see the final assembly.
Have you considered buying a used starter motor wire from ebay just for the grommet you need? They're listed from $9 upward. Just a thought.
Dick Eastman
Post by Dick Eastman » Mon Dec 12, 2016 7:08 pm
Seadog wrote:Looking great. Can't wait to see the final assembly.
Thanks - can't wait to see end result myself - that' why I call it "slowly but surely".
I may have to go to e-bay for the terminal cover - got the grommet covered. The only problem with 50 year old rubber parts is they are usually dried out and cracked. I may try to find a cover for a garden tractor app, as the wire is 6ga.
Dick Eastman
Post by Dick Eastman » Mon Dec 12, 2016 7:20 pm
I installed a Sigma bicycle speedometer to my Kaw, and now they make them wireless. They have odo, trip odo, time, speed, avg speed, max speed. I plan to use one for this project. I designed and machined the bracket for the AutoMeter temp gage, as well - I really like their products. I plan to mount the AutoMeter tach centered above the headlight, and the Sigma offset, closer to bars.
Copy of IMG_2558 (Medium).JPG (67.67 KiB) Viewed 5854 times
IMG_2564 (Medium).JPG (68.23 KiB) Viewed 5854 times
Post by Seadog » Mon Dec 12, 2016 7:23 pm
Dick Eastman wrote:I may have to go to e-bay for the terminal cover - got the grommet covered. The only problem with 50 year old rubber parts is they are usually dried out and cracked. I may try to find a cover for a garden tractor app, as the wire is 6ga.
Could this work?
http://www.ebay.com/itm/Starter-Motor-T ... Da&vxp=mtr
border0_3
Post by border0_3 » Mon Dec 12, 2016 10:15 pm
Hi Dick,
Your doing some excellent engineering works there.
A couple of alternate sources for rubber boots.
http://www.ebay.co.uk/itm/1x-Durite-Ins ... 1731198233
http://www.ebay.co.uk/itm/1x-Durite-Ins ... 0963816027
Keep up the great work - regards Richard
