CL77 front fender stay (top mount)
Glenn-N
Post by Glenn-N » Sun Nov 27, 2016 2:56 pm
Managed to find these 2 in NOS condition, now I started attaching the bracket to the fender blade using the correct OEM bolts.
The 2 bolts that go on top don't have a welded-on nut to lock them in place...
I have 2 new Honda 5mm nuts but they don't fit, the wire thread seems to be different.
Anyone who has a correct part number or reference for the 5mm nuts?
Or any info about how the 2 bolts on top should be attached originally?
Glenn-N
Post by Glenn-N » Mon Nov 28, 2016 5:58 pm
Seems like it's normal for new produced nuts and bolts not to fit.
Recently ordered many OEM nuts/bolts using the correct ref. number at CMSNL but already had some screws that don't fit, eg. taillight and headlight screws. Different thread.
Re: CL77 front fender stay (top mount)
Post by LOUD MOUSE » Mon Nov 28, 2016 6:48 pm
I believe you wil find the nuts on the fender are JIS and if you got that thread bolt you are fortunate for sure.
If you have 2 more bolts of that thread you can get in touch with me as I have one of the fender plates with the JIS nuts. ..................lm
Glenn-N wrote:Managed to find these 2 in NOS condition, now I started attaching the bracket to the fender blade using the correct OEM bolts.
malcolmgb
Post by malcolmgb » Fri Dec 09, 2016 3:54 pm
Nick at Ohio Cycle does reproduction JIS M5 chrome bolts.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Glenn-N
Post by Glenn-N » Sat Dec 10, 2016 1:44 pm
Thanks.
Problem solved.
I have the original NOS Honda JIS bolts, and ordered 2 JIS 5mm nuts on eBay.
Post by LOUD MOUSE » Sat Dec 10, 2016 1:50 pm
Good deal. ...............lm
Glenn-N wrote:Thanks.
Problem solved.
