aircleaner cover
Goodbrew
aircleaner cover
Post by Goodbrew » Wed Nov 28, 2007 8:03 pm
Hi Guys
Can any of you please advise me of the diameter of the combination switch hole in RH aircleaner cover of the CL72. I am trying to get the detail correct for my bike.
The diameter changed with a modification of the switch at frame number CL72 1001045.
If someone can tell me their frame number and hole diameter I can work out if what I have is correct or not.
ggray
Side cover
Post by ggray » Thu Nov 29, 2007 8:52 am
Do you have the type ignition switch that is attached with two flat head screws through the frame bracket?
'65 CL77 Owner
Goodbrew
Post by Goodbrew » Fri Nov 30, 2007 11:25 pm
Hi ggray
Thanks for you interest !
The ignition switch is missing completely at the moment ! The mounting point does have the two bolt holes but I think this may have been "modified at some stage as my frame number suggests it should not have that type of switch.
I was hoping someone could measure a side cover hole diameter from a bike that is "original" and I could then compare it to mine and tell if it has been enlarged at all?
ggray
Side Cover
Post by ggray » Sat Dec 01, 2007 1:27 am
I'll measure mine tomorrow (Saturday) and let you know what the diameter is.
Gary
'65 CL77 Owner
Goodbrew
Post by Goodbrew » Tue Dec 04, 2007 8:16 am
Hi Gary
Have you had a chance to have a look yet ?
Dean
1965 CL72
Frame number CL72 1000235
Engine Number CL72E 1000238
Naracoorte, South Australia
