Kick start issues
Beamish
Kick start issues
Post by Beamish » Mon Aug 15, 2016 10:03 pm
I changed my clutch cable this weekend. Put everything back together, clutch works great but now every time I use electric start the kick start flops down. And won't stay up if the bikes running. Turn bike off and pull it up it stays. I can kick it Then it flops again once running
Post by G-Man » Tue Aug 16, 2016 3:15 am
Did you retension the kickstarter spring when you put the cover back on?
Beamish
Kick starter
Post by Beamish » Tue Aug 16, 2016 7:29 am
I turned it once to get it all lined up. That put some temp sin on it. How much tension should be on it. Thanks for the help
Re: Kick starter
Post by G-Man » Tue Aug 16, 2016 10:20 am
If it was OK before then you need to put some more tension in the spring. The kickstarter shaft needs to be rotated fully clockwise against the stop before putting th ecase back on. If it is not against the stop that will lose some of the spring tension.
One possibility is that the roller bearing on the kickstart shaft that supports the gearbox countershaft is worn out. Once the bearing is damaged it tends to drag the kickstarter with the engine running.
That's a big job to fix requiring the cases to be split.
http://www.cmsnl.com/honda-cl77-scrambl ... ml#results
The rollers (25) support part 5 against part 18.......
Beamish wrote:I turned it once to get it all lined up. That put some temp sin on it. How much tension should be on it. Thanks for the help
Post by Seadog » Tue Aug 16, 2016 12:39 pm
After rotating the kickstarter shaft all the way to the right (clockwise), as G-Man has stated, all of the index marks on the kickstart assembly inside the side case must be aligned and held in place as you put the side case back on. See:
http://www.honda305.com/forums/proper-k ... t4545.html
Beamish
Thanks
Post by Beamish » Wed Aug 17, 2016 8:05 am
Thank you for the info
Re: Thanks
Post by Seadog » Wed Aug 17, 2016 11:01 am
You're most welcome; let us know how it works out.
Beamish wrote:Thank you for the info
