Signal not flashing
Post by G-Man » Wed May 04, 2016 2:59 pm
I did get some pistons for my 1961 CB72. They have a lot of stuff but not a lot that I need, unfortunately.
http://www.harpersofcowleyltd.co.uk/sit ... LIST-1.pdf
Seadog wrote:Nice find, G. Hope you were able to snag some other good stuff too.
G-Man wrote:Seadog
I always try to save things if I can, but I just purchased a NOS one with bracket from a dealer in the UK that is clearing out some stuff.
Post by Seadog » Wed May 04, 2016 3:13 pm
You did well. Lots of stuff there. I wonder if large parts houses like CMS jump on those types of sales.
Robbie63
Post by Robbie63 » Wed May 04, 2016 3:31 pm
G man is the flasher simple to take apart,never done this before,thought it was a sealed unit.ps my 63 150 benly has a similar looking flasher ,but 6 volt system,would this possibly work..
Eljeef
Post by Eljeef » Wed May 04, 2016 5:40 pm
Hello. If I might chime in, there are two bolts holding the bracket of your flasher to the frame. Remove those and take the flasher out. You probably already know you have to remove your air cleaner to get in there. Once you have the flasher in your hand and the wire harness disconnected you can carefully bend back the three metal tabs that hold the barrel innards in place. Carefully withdraw the guts of it all and have at it.
Regards, Jeff.
1964-C77 305 Dream
2002 BMW R1150GS
Post by LOUD MOUSE » Wed May 04, 2016 5:44 pm
They just bought the stock of WESTERN HILLS HONDA. ....................lm
Seadog wrote:You did well. Lots of stuff there. I wonder if large parts houses like CMS jump on those types of sales.
Post by G-Man » Thu May 05, 2016 7:17 am
Good for us in Europe, I suppose. Not so good for guys in the US. I wonder if they'll run into the same problem that David Silver did? There may be a CMS in the United States, soon......
LOUD MOUSE wrote:They just bought the stock of WESTERN HILLS HONDA. ....................lm
Post by G-Man » Thu May 05, 2016 7:20 am
Jeff
Spot on. There's no such thing as a sealed unit to an enquiring mind........ :-)
To answer the question on 6v and 12v flasher units. It might just work but, at best, the flash rate will be all wrong.
Eljeef wrote:Hello. If I might chime in, there are two bolts holding the bracket of your flasher to the frame. Remove those and take the flasher out. You probably already know you have to remove your air cleaner to get in there. Once you have the flasher in your hand and the wire harness disconnected you can carefully bend back the three metal tabs that hold the barrel innards in place. Carefully withdraw the guts of it all and have at it.
Regards, Jeff.
