Front fork disassembly
Re: Recommended tools for removing bushing pins
Post by G-Man » Thu Mar 24, 2016 12:49 pm
Dave
Always good to see fresh ideas. Many thanks for sharing that.
dave_c wrote:Hi all, I'm a little late to this party but I wanted to show you what I ended up with as a very effective set of tools for pushing these pins out. From way back I had a seal puller and an old school automotive drum brake adjusting tool. Combining these as shown allowed a very controlled application of force to the back of the pin. Without the brake tool (or similar) backing up the seal puller, the fulcrum was in the wrong place and I broke the hardened tip of the puller.
CeeBee72
Removing pins from lower bush on front forks
Post by CeeBee72 » Thu Feb 08, 2018 3:04 pm
Just got to the point of dismantling the front forks and came across the pin removal problem. I designed and made a tool to push them from the inside. It worked a treat :-)
I have tried to upload a picture but get informed
"Tried to upload empty file"
Any ideas? JPG file of 353k
Re: Removing pins from lower bush on front forks
Post by G-Man » Fri Feb 09, 2018 5:16 am
Use Flickr and put in a link. Simples.
CeeBee72 wrote:Just got to the point of dismantling the front forks and came across the pin removal problem. I designed and made a tool to push them from the inside. It worked a treat :-)
CeeBee72
Fork pin removal tool link
Post by CeeBee72 » Fri Feb 09, 2018 8:33 am
Re: Fork pin removal tool link
Post by Seadog » Fri Feb 09, 2018 8:57 am
You have to make the photo public.
CeeBee72
Fork pin tool
Post by CeeBee72 » Fri Feb 09, 2018 9:12 am
Every day is an education! It should now be public.
Re: Fork pin tool
Post by Seadog » Fri Feb 09, 2018 9:18 am
As it should be!
Nice tool. Your other photos are very good as well. Quite a project you have on your hands.
CeeBee72 wrote:Every day is an education! It should now be public.
