Rotating kick start lever
redtr4
Post by redtr4 » Sun Mar 20, 2016 12:17 pm
Not sure whats going on here but got my cb77 started and running but the kick start lever swings forward down below the foot peg ever time i start it.. I can manually pull back up but swings back down when i let go. Any help greatly appreciated. Kurt
OldScrambler
Post by OldScrambler » Sun Mar 20, 2016 2:17 pm
Likely wound the 'wrong' way for spring tension...........some have been known to install the spring 'backwards'...............easy fix.
Post by G-Man » Sun Mar 20, 2016 2:32 pm
Could be a problem with the roller bearings inside the gearbox.
See items 25 and 6 on this page
http://www.cmsnl.com/honda-cb72-general ... ml#results
The kickstart shaft runs through the gearbox countershaft and when the bearing goes it can drag the kickstart when the engine is running.
Vince Lupo
Post by Vince Lupo » Tue Mar 22, 2016 5:48 pm
Could be a worn kicker shaft, in which case DO NOT ride the bike. I had the same thing happen when I would be riding in 2nd gear. I'd look down and see the kickstart lever moving forward and then all of a sudden go straight down on its own. If it is doing that, DO NOT ride the bike. You could do serious damage to your transmission.
redtr4
Post by redtr4 » Wed Mar 23, 2016 8:37 am
vince.. any further info on remedy? sound like have to tear motor apart and replace what?
Post by G-Man » Wed Mar 23, 2016 9:17 am
See my post above. Roller bearings and potentially kickstart shaft.... Items 25 and 6 on CMS page.
Vince Lupo
Post by Vince Lupo » Fri Mar 25, 2016 3:28 am
Graham's thought is basically the same as mine -- only solution is to have a look and potentially replace both the roller bearing and the kicker shaft. If that's in fact what it is.
