CB77 Tail Light
Steve P.
CB77 Tail Light
Post by Steve P. » Fri Feb 26, 2016 6:06 pm
Hello, I have a pristine 1967 CB77 with only 1000 miles on it. My battery is good and it runs nice.
My tail light brake like works fine, however, my taillight running light won't light up.
The bulb is fine, all other electrical is fine.
Can anyone please give me suggestions.
Thanks much
Steve P
48lesco
Post by 48lesco » Fri Feb 26, 2016 8:39 pm
Steve - Check for 12V at the socket. If none or low, trace the white wire back to its bullet connector. Clean it and check for 12V there. Other than that, could be a break in the white wire somewhere. Sounds like the contacts in your ignition switch are OK if the headlight is working. PM me if you need the wiring diagram.
-48
revlover
Post by revlover » Sat Feb 27, 2016 10:38 am
Steve, Try placing a jumper wire between the HL (green wire) and TL (white wire) terminals on your ignition switch. If that restores the tail light function, the ignition switch is the culprit. You may also leave the connection bridged permanently if you don't plan to use the park light feature (third position on the ign. switch), instead of replacing it. I did that once on another bike with the same problem. Hope this helps.
Doug
Steverino
Post by Steverino » Sat Feb 27, 2016 8:36 pm
I want to see a pristine CB77. Post a couple pics.
The other Steve
