Okay, I Need Some CB77 Crankshaft Bearing Info
bill440cars
Post by bill440cars » Sun Oct 21, 2007 4:57 pm
I've gotten confused on the type of bearings on the CB77 crankshaft. I've got a parts breakdown from crotchrocket.com for a 61 CB77, that will show what I'm talking about. Well this breakdown apply to a 63 also? This concerns items #6, 7, 17 & 18 Or 16. What determines which set of bearings is on that side? I have a crankshaft (that I got off of ebay) and that side has no bearing at all. Other than that, the crankshaft is in great shape. Any info appreciated.
Later on, Bill
Post by davomoto » Mon Oct 22, 2007 4:32 pm
I believe you're reffering to the right side of the crank. The origional bearing was a flat needle bearing type. They were superceded by a roller bearing on the later models. That will probably be all you can find at this point, although you could try western hills honda or ohio cycle for the origional type.
bill440cars
Post by bill440cars » Wed Oct 31, 2007 11:47 pm
davomoto, Sorry I'm a bit behind in getting back to the forum. Thanks for your input. I'm looking into that bearing situation.
Later on, Bill
Post by LOUD MOUSE » Thu Nov 01, 2007 7:46 am
Your crank came with a pin roller bearing (parts books show 20 pins) assembly. The other is a BALL TYPE BEARING that can be used if the bearing contact surface on the crank is warn/gouged. I have the pin type parts if you need them. ....................lm
bill440cars wrote:davomoto, Sorry I'm a bit behind in getting back to the forum. Thanks for your input. I'm looking into that bearing situation.
Later on, Bill
bill440cars
Crankshaft Bearing
Post by bill440cars » Thu Nov 01, 2007 4:38 pm
Hey lm,
I'm listening. I got myself a fine CB77 crankshaft that is in great shape except that I don't have a bearing setup on that side. The rest seems good to go! I shoulda known that you'd either have the stuff or know where to get it. So, what kind of a deal are are we talking?
Later on, Bill
Re: Crankshaft Bearing
Post by LOUD MOUSE » Thu Nov 01, 2007 10:08 pm
Get to me private and I'll give ya a price. .....................lm
bill440cars wrote:Hey lm,
Later on, Bill
