Cylinder head washersCylinder head washersIs it necessary to use crush washers on all 8 studs?
Can I use 6 good steel washers, and put crush washers on the 2 outside front studs where the oil pressure is?
Re: Cylinder head washers1967 HONDA installed copper (ZINC PLATED) washers on the 4 corners and 4 flat steel on the middle 4. .......................lm
Re: Cylinder head washersExcellent - I have 4 new OEM washers. I will use them on the 4 corners. Thanks LM.
Re: Cylinder head washersPut them on the rotor and see if they stick.
I have a bin full of Look Similar and they were steel. ....................lm
Re: Cylinder head washersThey do stick. But they are the correct part number according to the fiche for my engine number (CP77E-1001821). It specifies 90441-286-000 x 8.
Re: Cylinder head washersLike I said I have a bin full of those. (STEEL). ..................lm
