Tubing
modelman
Tubing
Post by modelman » Sun Sep 06, 2015 8:05 am
Every single rubber pipe on my CB77 was missing when I got it, & looking at loads of photos & other searching, I still can't work it out, SO,
1 x nipple in the middle of the head top cover pointing rearwards,
2 x sticking out of the lower rear of the head by the carbs,
1 x on each of the new air-filters pointing forwards.
Then there's 1 on each fuel-bowl pointing rearwards & down, what goes where & the routing please.
Different question, here in the UK, what oil for the engine?
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Re: Tubing
Post by LOUD MOUSE » Sun Sep 06, 2015 8:24 am
modelman wrote:Every single rubber pipe on my CB77 was missing when I got it, & looking at loads of photos & other searching, I still can't work it out, SO,
DOWN THE BACK OF THE HEAD ON THE LEFT SIDE OF THE CAM CHAIN TENSIONER INTO THE VALLEY OF THE UPPER CASE TO THE RIGHT AND NEAR THE HOLE WHERE THE SPROCKET IS ON THE OTHER SIDE OF THE CASE.
A PLASTIC "Y" WITH TUBING TO BOTH OF THOSE AND THE SINGLE GOES TO THAT VENT ON THE RIGHT AIR CLEANER.
CLOSE OFF THE LEFT SIDE AIR CLEANER TUBE.
NOTHING GOES ON THESE ...............................lm
modelman
Post by modelman » Sun Sep 06, 2015 2:02 pm
Great, thank you.
Does one from the top actually go through the grommet & exit into the right side case?
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Post by LOUD MOUSE » Sun Sep 06, 2015 2:41 pm
If your hole under the grommet in the case is large enough you can put the hose through it. .....................lm
modelman wrote:Great, thank you.
