Will a CA77E Motor fit my 63 superhawk CB77E
Will a CA77E Motor fit my 63 superhawk CB77EHello I need a little help here Im trying to restore a 1963 superhawk the orignal motor is locked up ,So I found a 305 Dream 1970 motor ,it all looks the same I was planning on just changing the head ,will this work and all help is needed .
There are some differences. I think the top plate is different, not a problem to switch, and the rest of the mounting is the same, BUT- the main differences are internal. 360 (dream) vs 180 crankshaft, different dome on the pistons, I'm not sure if the dream piston will clear the head (different compression chambers in the heads.) Also different cams due in part to the different crankshafts.
63 CA78
thank you for your info this is where things get a bit different for mine,I bought a used crank on ebay once I got it and got my motor apart i noticed a few things that were different on mine , mine runs single point and the crank I pulled out has both the piston go up at the same time not like other CB I have read on . this bike came from Japan not and export model , a service member bought it knew and was the only owner he brought it to the states would that make a big deference in what motor I have
I was looking at some of my posting from before I found this one that Mike reply back with (I have swapped engines several times between different years production. There is no problem as far as that goes. Externally they are all the same, and as I recall any internal changes are minor, and most internals are common to all.)
Mike Mullins Demotte IN
