CL77 Headlight
Bee
CL77 Headlight
Post by Bee » Thu May 21, 2015 9:03 am
Can anyone tell me if a headlight with part number 33100-286-672 is a suitable replacement for a late model 1967 CL77 headlight that has a part number of 33120-268-670? They look the same on eBay but I can't tell if they are the same diameter
bamacl
Post by bamacl » Thu May 21, 2015 4:07 pm
Yes. Used one myself.
OldStan
Post by OldStan » Thu May 21, 2015 10:35 pm
Looking for one for my late 67 CL 77 as well. I'm not sure some of the sellers part numbers can be trusted without pictures of the back. I've seen several with the right part number, but the wrong style mount. Mine has the ears for the screws, I think its supposed to be 33120-283-000. The numbers you mentioned use springs clips to retain the bulb, but see both styles under those part numbers.
63 CA78
bamacl
Post by bamacl » Thu May 21, 2015 11:24 pm
I used the 286 part # sold as a unit with rim and it was a perfect fit for a 67. It is also the correct replacement
part. No clips.
OldScrambler
Post by OldScrambler » Fri May 22, 2015 9:37 am
as used on the 450 Black Bomber...........
Bee
Post by Bee » Fri May 22, 2015 10:38 am
I bought it because it has the ears on the back that match my current 67 CL77. I'll post once I get it but it certainly looks like the one for 67 model.
