water in right side case
Woodsie
Post by Woodsie » Tue May 19, 2015 6:25 pm
I think some water went through the hole in the right hand side engine case where the breather from the top of the engine goes through. It is a 305 ca77. I am wondering if I have to remove the right side cover to determine this. I don't think I am seeing the bottom of the case when looking in the inspection hole after removing the rubber plug.
Hamamatsu Nippon
Post by Hamamatsu Nippon » Tue May 19, 2015 8:18 pm
If enough water got into the right side case, it would just leak out. A lot of 305 owners have problems with oil leaking from there. There is no gasket, plus there is a drain hole cast into the bottom to direct any fluids away.
1967 CA78
1965 CM90
Soichiro Honda
Woodsie
Post by Woodsie » Wed May 20, 2015 1:17 am
Thank you.
