CL 72 Kickstarter woes
connor1
Post by connor1 » Tue Apr 28, 2015 10:12 pm
Pics
cover with lever.jpg (394.66 KiB) Viewed 4023 times
connor1
Post by connor1 » Tue Apr 28, 2015 10:16 pm
another pic
coil spring.jpg (453.19 KiB) Viewed 4017 times
connor1
Post by connor1 » Tue Apr 28, 2015 10:17 pm
spline
mike in idaho
Post by mike in idaho » Wed Apr 29, 2015 4:22 am
You should pull that piece out of the cover and check it out, if slipped on the spline it's likely cracked.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
OldScrambler
Post by OldScrambler » Tue May 05, 2015 1:17 pm
+1 with Mike................remove the 10mm cap-bolt to release any remaining spring-tension............then the clip...........Examine closely..........cracks are sometimes hidden. Pay attention to the spring for proper re-assembly.
connor1
Post by connor1 » Tue May 05, 2015 7:41 pm
Well guys you were exactly right! Here are a couple of pics of the cracked knuckle.
CL72 kickstart knuckle resize.jpg (379.11 KiB) Viewed 3870 times
connor1
Post by connor1 » Tue May 05, 2015 7:43 pm
and another...
HondaCL72 kickstart knuckle crack resize.jpg (298.47 KiB) Viewed 3865 times
