Bent Clutch Actuator Rod - How?
Messing about in my right case area today and noticed that the clutch actuator rod is bent, flattened a bit and scored on the portion inside the case. The detent for the ball bearing is also off center. Any idea how this happens? Before I buy a used replacement, is there any variation in early or late model rods that I should know about? Mine is approximately 9-11/16 inches long. The seal should also be replaced. Hopefully I can find one at the Honda dealer.
- IMG_0424.JPG (164.18 KiB) Viewed 3404 times
- IMG_0422.JPG (177.45 KiB) Viewed 3404 times
That part is the same for all 250/305 engines. ........lm
Seadog wrote:Thanks, G-Man. I guess anything is possible. The fact remains that I have to replace it and the seal. Will any CA77 clutch rod do, or must I find a specific one for my '64?G-Man wrote:Maybe the drive chain came off and caught it......
