connecting rod sleeves?
Farm Shop
Post by Farm Shop » Wed Dec 10, 2014 4:09 pm
The small ends of my connecting rods have just enough play in them with a new wrist pin installed that something needs to be done.
I have read posts about Honda having made oversize wrist pins but I was wondering if anyone has successfully bored and sleeved the small end of the rod to accept a standard pin again?
FS.
Post by G-Man » Thu Dec 11, 2014 2:09 am
Not a lot of metal for sleevng the rod. Oversized sleeves are available still.
Mod code -305
Farm Shop
Post by Farm Shop » Thu Dec 11, 2014 11:05 am
I see that David Silver has them available here in the states. I was just curious if anyone has attempted sleeving the rods.
And with the wiseco pistons I decided to go with the Honda pins would need to be shortened.......
Thanks for the reply G man I will keep the post updated when my machine shop let's me know what they can do!
FS
jugger18
Post by jugger18 » Thu Dec 11, 2014 11:52 am
I am over in Oregon, not too far away. What Machine shop are you using?
Farm Shop
Post by Farm Shop » Thu Dec 11, 2014 12:55 pm
Pakes' engine and machine in Janesville
He has done some work for me in the past always with fantastic results.
Farm Shop
Post by Farm Shop » Fri Dec 12, 2014 12:35 pm
Soooo..... The machine shop said it wouldn't be a problem to shorten the Honda wrist pins to fit the wiseco pistons and bore the pistons for the oversize pins.
But they won't bore the rods. I know I've seen posts about people doing it with a straight flute reamer?? Does anyone have any input on how difficult it would be to do that way myself?[/list]
Post by G-Man » Fri Dec 12, 2014 1:57 pm
The problem is getting the reamer to run perpendicular to the rod. Ideally you would dismantle the crank and ream the rods on a vertical miller.
Making a tool that used one rod as a guide for the the other might work.
I have some rods to do and I was thinking of making a tool using a scrap cylinder barrel as a guide.
I've not worked out the detail yet.....
