CA78 VIN
CA78 VIN
I have a CA78-103689. From the postings I have seen, they should be starting with 3XXX, but clearly this one starts with 1XXXXX and is titled in FL. Any comments?
a "3" prefix was for 1963. Honda changed the numbering sequence in 1964 and all bikes began with "10". Yours is later than '63.
How about some pictures?
- Numbers.jpg (104.72 KiB) Viewed 2618 times
CA-78
Thanks for the update, I believe you are correct, it is a 1965. Tried to send a picture, but the Forum says the file is too large. And, I have no idea how to change the file size.[/img]
Re: CA-78
One easy way is to open it with Paint, then use the "resize and skew" tab.mentor53ja wrote:Thanks for the update, I believe you are correct, it is a 1965. Tried to send a picture, but the Forum says the file is too large. And, I have no idea how to change the file size.[/img]
