Oil slinger disassembly
R100
Post by R100 » Fri Jul 18, 2014 3:01 pm
That pin in the shaft (just outside the washer).
Press fit? How best to remove it?
Re: Oil slinger disassembly
Post by LOUD MOUSE » Fri Jul 18, 2014 3:42 pm
Why remove it?. ......lm
R100 wrote:That pin in the shaft (just outside the washer).
R100
Post by R100 » Fri Jul 18, 2014 3:50 pm
LOUD MOUSE wrote:Why remove it?. ......lm
I thought it had to be removed in order to remove the cap to clean out the slinger cup.
Am I mistaken about how to clean it?
Post by LOUD MOUSE » Fri Jul 18, 2014 4:07 pm
Get a grip on the end of the shaft with the locator pin and pull the shaft out. ........lm
R100
Post by R100 » Fri Jul 18, 2014 4:25 pm
LOUD MOUSE wrote:Get a grip on the end of the shaft with the locator pin and pull the shaft out. ........lm
OK. Done.
The shaft is snug in the slinger. Tapping with a plastic hammer moves it. Maybe a piece of wood dowel to push it all the way out?
Hahnda
Post by Hahnda » Fri Jul 18, 2014 8:20 pm
The slinger should be free to rotate on that shaft. If the engine hasn't ran in a while it might just be built up with crud on the shaft and once cleaned up it will rotate fine. If not you might have to find another.
