Remove key switch assembly
Boz64
Post by Boz64 » Sat Jun 28, 2014 3:13 pm
I have a 1964 CA77E and need to remove the key switch assembly from the speedometer/headlight housing. I can't see the apparent way to go about this and would like some advice on how to proceed. Is there a special tool required? Thanks for your help!
Boz64
Post by G-Man » Sat Jun 28, 2014 4:12 pm
You just have to remove the ring on the outside of the switch. You can try to find or make a C spanner or you can try gently tapping the ring undone with a piece of hardwood in one of the slots.
Boz64
Remove switch assembly
Post by Boz64 » Sun Jun 29, 2014 8:19 pm
Thanks so much for the tip! Made a tool and got it undone.
Boz64
Post by G-Man » Mon Jun 30, 2014 1:05 am
You're welcome. Please put your location in your profile and you may find someone locally that you can share your problems / successes with.
Also - we like photos!
