Hello
I have been working on my cb77 cylinder head. As mentioned in another thread someone previously has cut the spark plug holes out by 2mm. I managed to cross reference the thread size and find plugs
The issue I have is that there is a small gap opened up into the casting above the steel skull cap. I fed a piece of stiff wire and it is quite open. Perhaps a flaw in the original casting.
I am hoping that there is no oil galleries and the best I can tell this is the case.
Has anyone seen this before? I am hoping to leave or perhaps fill with some liquid steel two part bonding material. Not sure if the heat will be an issue.
The threads below are fine.
Spark plug hole issues
- Waveblaster
- head_plug_resize.JPG (121.72 KiB) Viewed 1056 times
