Removing small bolts from stainless seat trim
dreamr
Post by dreamr » Mon Jul 23, 2007 3:17 pm
These tiny bolts appear to be brass, most are not unscrewing off the nut, and it appears that the entire bolt and nut are turning when I try to remove them. I sprayed some WD40 on them before I started. I cannot begin my seat cover replacement until the stainless piece is removed. Anybody come up with a trick to get these off?
I can only imagine the challenge to reinstall this part! Thanks.
Re: Removing small bolts from stainless seat trim
Post by LOUD MOUSE » Mon Jul 23, 2007 5:25 pm
I use a carbide disc on my air tool and grind the nut away.
I then use new screws washers and nuts. ...........lm
dreamr wrote:These tiny bolts appear to be brass, most are not unscrewing off the nut, and it appears that the entire bolt and nut are turning when I try to remove them. I sprayed some WD40 on them before I started. I cannot begin my seat cover replacement until the stainless piece is removed. Anybody come up with a trick to get these off?
dreamr
Post by dreamr » Thu Jul 26, 2007 2:54 pm
Thanks for confirming what I figured I would have to do, lm. I've tried to reuse as many parts as possible as I work on this project but those pieces were not going to be salvagable.
BTW, the cover from SCI was a perfect fit and the seat came out great!
Post by LOUD MOUSE » Thu Jul 26, 2007 7:50 pm
I hope I was of help. Glad you are happy how it came out. ...........lm
dreamr wrote:Thanks for confirming what I figured I would have to do, lm. I've tried to reuse as many parts as possible as I work on this project but those pieces were not going to be salvagable.
