Anyone run CB or CL77 wheels on CA77
Prosuperstar
Post by Prosuperstar » Tue Apr 15, 2014 11:57 pm
Just wondering what's needed to run 18" wheels from either model
Cheers
Post by G-Man » Wed Apr 16, 2014 1:20 am
CL77 wheels are 19 inch
CB77 wheels are 18 inch
You may get fender clearance issues with the 19 inch wheels and you will have to sort out spindle diameters and spacers. CB and CL use cable rear brake actuation so you may have to rig that up for your Dream.
Front brake torque arm on the dream is different from the other two so that will need adapting at the brake anchor on the brake plate. Also you will need to check out the rotation and ratio of the speedo drive.
The CE71 Dream sport used 18 inch wheels but I'm not sure whether it had a different fender arrangement to compensate.
http://www.examiner.com/article/1959-ho ... stery-bike
Are you after the better brakes or bigger wheels? If just better brakes some CB350 parts might work better / cheaper.
Prosuperstar
Post by Prosuperstar » Wed Apr 16, 2014 1:39 am
G-Man wrote: Are you after the better brakes or bigger wheels? If just better brakes some CB350 parts might work better / cheaper.
I'm primarily looking to install bigger wheels
Post by G-Man » Wed Apr 16, 2014 7:09 am
You could just have bigger rims laced to the hubs.
http://www.buchananspokes.net
malcolmgb
Post by malcolmgb » Wed Apr 16, 2014 1:06 pm
Also likely to upset the handling. 'Change for changes sake'
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
