Seen this before?
malcolmgb
Seen this before?
Post by malcolmgb » Mon Mar 31, 2014 4:06 pm
The swing arm bolt was very difficult to remove and I had to hammer it and at the same time kept turning the bolt, when it finally came out I noticed the bush in the frame had also moved, looking closely at the gap it appears threaded, I have since tried using grips to screw it back in but no luck yet, I may try a little heat next. Any experience of this?
https://www.dropbox.com/s/in781puqr4dks9n/DSC_0081.jpg
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
malcolmgb
Post by malcolmgb » Sun Apr 06, 2014 2:39 pm
Has nobody any experience of this?
I re-examined it today and maybe the bush is undercut to allow the bush shoulder to push right up to the frame tube, I have possibly seen the undercut as the start of a thread.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Sun Apr 06, 2014 3:46 pm
Malcolm
I would just use a piece of studding and pull it back in.
malcolmgb
Post by malcolmgb » Sun Apr 06, 2014 5:17 pm
That's my plan now Graham, I was just concerned that it might be threaded still and that could cause me problems.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Mon Apr 07, 2014 12:48 am
Malcolm
Threading that part sounds a bit sophisticated (and unnecessary) for Honda. If you apply steady force you are less likely to distort it than hammering back in. Apply a bit of heat and it should just go back in.
malcolmgb
Post by malcolmgb » Thu Apr 10, 2014 12:41 pm
Done okay, used a long piece of threaded rod and it went back in easily, cold.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
