Alternator cover screws
garncarz
Post by garncarz » Sun Jan 26, 2014 9:33 am
48lesco wrote:Another thought, most tap and die sets have both the M5x.8 and M5x.9 die for some reason, and I have successfully "converted" new .8 pitch screws to .9. As OldStan said, not much stress on that part either way. This way though, you don't modify an original part and I'm not sure if that's important.
-48
Well, I have the new .8 screws. Let's see if I can find a M5x0.9 die. Thanks for the tip.
garncarz
Post by garncarz » Mon Jan 27, 2014 7:29 am
-48
I ordered a M5x0.9 die from MSC.
http://www.mscdirect.com/browse/?navid= ... ic+hex+die
48lesco
Post by 48lesco » Mon Jan 27, 2014 10:27 pm
You have probably already figured this out, but it's going to be hard to turn the phillips head screw into the die. I used a phillips bit chucked in a drill press with the die clamped in a vice. Steady pressure on the bit and turn it by hand. You might be able to do it without the drill press, I didn't try.
garncarz
Post by garncarz » Tue Jan 28, 2014 8:04 am
48lesco wrote:You have probably already figured this out, but it's going to be hard to turn the phillips head screw into the die. I used a phillips bit chucked in a drill press with the die clamped in a vice. Steady pressure on the bit and turn it by hand. You might be able to do it without the drill press, I didn't try.
Put the die in a bench vise, turn the screw in with a magnetic driver.
Post by LOUD MOUSE » Tue Jan 28, 2014 8:35 am
As I know it it is much easier to turn a tap in the part on the stator than to turn a screw in the die.
I do this with every engine I restore now. .................lm
48lesco
Post by 48lesco » Tue Jan 28, 2014 8:54 am
Well, the cat's out of the bag now... Why would you ruin an expensive, perfectly good 50-year-old vintage part instead of a 29-cent screw??????? You young fellas are always looking for an easier, quicker, cheaper way.
:)48
garncarz
Post by garncarz » Tue Jan 28, 2014 10:29 am
48lesco wrote:Well, the cat's out of the bag now... Why would you ruin an expensive, perfectly good 50-year-old vintage part instead of a 29-cent screw??????? You young fellas are always looking for an easier, quicker, cheaper way.
:)48
Not ruining anything. I am rethreading a new M5x0.8 screw to 0.9 pitch, to fit the alternator cover.
