Hello Group,
I've got a '64 CL72 under restoration and have concerns about the engine compression. Both cylinders are just over 120 lbs. I have the factory shop manual which lists the lower service limit at around 113 lbs so I would not have worried about it too much except that I also have the Bill Silvers restoration guides which indicate the compression should be higher (much higher). Is this thing going to run?
CL72 Compression Question
CompressionI think you'll be fine with 120 lbs.
