Centrifugal oil filter question
rbaselt
Post by rbaselt » Tue Feb 06, 2007 9:14 am
There is a great deal of racket from the chaincase of my recently rebuilt 1965 CL77 engine. Upon opening the chaincase, I find that the centrifugal oil filter with its sprocket and chain are free to rotate when nothing else is moving. Did I assemble something improperly? The other possibility is the primary chain, which has a tensioner with a new rubber wheel, but the upper portion of the chain still has a fair amount of free play. I'm attempting to locate a supplier for a new primary chain.
--Randall
joeweir1
Post by joeweir1 » Tue Feb 06, 2007 4:01 pm
Something must be up with the sprocket on the crank!
FiremanBob
Post by FiremanBob » Tue Feb 06, 2007 9:02 pm
My oil filter definitely does not move independently from the main sprocket. Must be an assembly issue.
Steven58
Centrifugal Oil Filter
Post by Steven58 » Wed Jun 27, 2007 8:29 am
On my CB72 I had the same problem last autumn. I then thightened down the locking nut and secured it with locking washer. Filter was then OK. Now when changing oil and checking filter, I find the filter in exactly the same state; it can move almost freely. What's happening??
joeweir1
Post by joeweir1 » Wed Jun 27, 2007 8:21 pm
Unless the sprocket on the filter is loose then the locking nut must not be tight enough.That would be the only expalanation.Joe
Randall Coleman
Oil filter turning freely
Post by Randall Coleman » Sun Aug 19, 2007 10:40 am
Refer to the parts illustration. Washer #10 is a cone shaped washer. The high center should be installed away from the engine. When the nut is tightened, the washer clamps down on the oil filter drive sprocket.
Steven58
Post by Steven58 » Sun Aug 19, 2007 2:06 pm
OK, that makes sense. Will check and revert regarding the positon of my washer. In late September, as I am on the road now....
