CL77 Handlebar question
Bee
Post by Bee » Sat Jul 20, 2013 8:34 pm
I bought a 1967 CL77 that I am "restoring". It runs well and really just needs some love and maintenance. At any rate it came with handlebars that have no cross bar. I've got to assume someone along the way put dream or super hawk bars on it. My question is I see a nice set of handlebars that look like CL77 bars but they have holes that it looks like they threaded the electrical through them. Were these holes stock at any time or did a pst owner just drill the holes themselves? If so should I assume this will make the bars weaker?
mike in idaho
Post by mike in idaho » Sun Jul 21, 2013 9:04 am
CL160s use a cross-braced handlebar, similar to the CL77. The 160 bars are drilled to put the wires inside. The welded in cross-bar on the 160 handlebars is smaller in diameter than the one on the CL77, otherwise they look about the same.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Bee
Handlebars
Post by Bee » Sun Jul 21, 2013 9:12 am
Thanks, I bet these are 160 handlebars.
zeerx
Post by zeerx » Tue Mar 04, 2014 9:55 pm
Rockymountainatvmc.com has some cheap "vintage bend" bars. I just bought a set....I'll let you know how they are.
zeerx
Post by zeerx » Sat Mar 08, 2014 9:22 pm
zeerx wrote:Rockymountainatvmc.com has some cheap "vintage bend" bars. I just bought a set....I'll let you know how they are.
Ok. Got the bars and here's what I found. They are going to replace a rusty, bent set of what I think are original cl77 bars. They are a little wider than the originals but seem to be a little lighter. Which probably means thinner steel. They are about 3/4 of an inch wider on each side at the mounting base and an inch wider each side at the handles. I'll try them for fit before I cut anything off the ends. The grooves in the mounting area fits exactly the mounting hold down bracket. The cross bar is very close to the same height. The chrome is very good. IMO these would be a good, inexpensive replacement for stock scrambler bars.....but would probably fold up like a bat wing if you have a get-off. But if that happens bent bars would be the least of your problems.
Rock on.
Mark13018
Post by Mark13018 » Thu Apr 10, 2014 8:38 pm
I just bought these:
http://www.ebay.com/itm/121295901768?ss ... 1439.l2649
They are pretty nice for a replacement but they are a little wide, as he states, and they do NOT have the holes drilled in for wiring. I can drill the holes myself though.
I did notice that he opened the package and took the labels off the bars and cut it off the plastic. These are just a current reproduction but I have no idea what company makes them or the model number.
I wish he would not have cut that info off but then again he is probably buying them for $25.00 and reselling them for $44. Not that I would start doing the same, I would just like to save a few bucks for my next set which I need. (who wouldn't?)
mike in idaho
Post by mike in idaho » Fri Apr 11, 2014 7:38 am
Why drill holes? The dimmer switch/horn wires run on the outside of the bars.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
