wiring in a new rectifier
mike in idaho
Post by mike in idaho » Fri May 03, 2013 7:40 am
Better yet to connect the black wire directly to the negative battery post.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
cadman
Post by cadman » Fri May 03, 2013 9:28 am
So what did you do with the pink wire to the ignition switch?
mike in idaho
Post by mike in idaho » Fri May 03, 2013 6:01 pm
The pink wire goes to the headlight switch, along with a yellow lead spliced into the yellow wire that goes to the rectifier. They are connected by the headlight switch for more output with the lights on.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
cadman
Post by cadman » Sun May 05, 2013 9:10 am
I know that Mike - Just can't figure out why folks are installing new rectifiers when you could use a rectifier/regulator combination.
