RECTIFIRE PROBLEM
N1YDP
RECTIFIRE PROBLEM
Post by N1YDP » Thu Apr 11, 2013 9:11 am
i have a 66 superhawk and when i hook the red wire with whote stripe to positive the lights dim and the rectifire starts to smoke.is the rectifire bad or i dont have a good ground or what?
Re: RECTIFIRE PROBLEM
Post by LOUD MOUSE » Thu Apr 11, 2013 9:59 am
Check all wire connections. ..........lm
N1YDP wrote:i have a 66 superhawk and when i hook the red wire with whote stripe to positive the lights dim and the rectifire starts to smoke.is the rectifire bad or i dont have a good ground or what?
N1YDP
Post by N1YDP » Thu Apr 11, 2013 11:56 am
it helps when youput in a new battery you put it in right!!!! duuuuh. my bad
cadman
Post by cadman » Thu Apr 11, 2013 9:18 pm
Note - because of reverse polarity you may have "cooked" the diodes in the rectifier. Meaning you now nave a paper weight.
Post by LOUD MOUSE » Fri Apr 12, 2013 8:46 am
The stock rectifier on a 1966 doesn't have Diodes. .......lm
cadman wrote:Note - because of reverse polarity you may have "cooked" the diodes in the rectifier. Meaning you now nave a paper weight.
cadman
Post by cadman » Fri Apr 12, 2013 7:50 pm
You are right no diodes - Not used to working with "old school" stuff.
