Front Brake Assembly
sibes67
Post by sibes67 » Sun Dec 16, 2012 11:02 am
Hub is cleaned up pretty well, but still need to remove the brake cable assembly which is held by that one bolt, under tension with the return spring. Any correct way to do this, what to be careful of, or is it straight forward? Need to clean underneath it yet, thanks.
Frt Brake Hub by sibes67, on Flickr
Post by davomoto » Sun Dec 16, 2012 12:11 pm
Yes, just remove bolt, and rock the arm off. There should be a punch mark on the arm and the shaft that ine up when reassmbling.
Davo
sibes67
Post by sibes67 » Sun Dec 16, 2012 9:32 pm
Right you are, piece of cake, thanks.
Ron
