Help with oil leak
Help with oil leak
Post by davomoto » Tue May 15, 2007 4:00 pm
I have a 64 305 CB77. I have replaced the right side crank bearing seal with a new one, the one I replaced looked new as well, but I still have an oil leak here. The back of the starting sprocket bushing area looks nice and smooth. Here's a couple pics of oil leak. Any suggestions? The seal is installed flush with outer case.
Thanks, Davomoto
Re: Help with oil leak
Post by LOUD MOUSE » Tue May 15, 2007 5:59 pm
How is the surface of the starter sprocket.
Ruff? Grooved? ..................lm
davomoto wrote:I have a 64 305 CB77. I have replaced the right side crank bearing seal with a new one, the one I replaced looked new as well, but I still have an oil leak here. The back of the starting sprocket bushing area looks nice and smooth. Here's a couple pics of oil leak. Any suggestions? The seal is installed flush with outer case.
Thanks, Davomoto
Starting sprocket
Post by davomoto » Tue May 15, 2007 6:15 pm
Thanks for the reply! Nice and smooth. I do notice that it is rather shallow, as in not a lot of surface are in seal.
Re: Starting sprocket
Post by LOUD MOUSE » Tue May 15, 2007 6:17 pm
Be sure it goes all the way up the tapered shaft with the rotor. .............lm
davomoto wrote:Thanks for the reply! Nice and smooth. I do notice that it is rather shallow, as in not a lot of surface are in seal.
oil leak
Post by davomoto » Tue May 15, 2007 6:25 pm
yes it goes all the way in, and the fixing plate bolts on flush. i just used my last new seal on a complete rebuild that's sitting on my bench. i will order more seals soon.
iol leak fixed
Post by davomoto » Sat May 26, 2007 10:43 am
So, I installed another new seal, but this time I coated the outside of the seal with three bond 1104, the same sealer I use for crank cases, and installed it flush with crank case. Problem solved. One note, the seal I installed was a 6.5, instead of the standard 7.5 width. it was what I had, and it worked. Thanks for the input.
Davomoto
deaddog
Post by deaddog » Thu May 31, 2007 7:14 am
Where did you buy your seal? How much did you pay for it? I have the same leak and am ready to purchase a seal.
