No, I placed it on the "pressure" side.Well done! All questions answered with clarity and backed up with empirical data. The only point I might argue with you Jensen (and I do so with great trepidation so maybe request further clarity is probably a better approach) is putting the medial filter on the suction side of the oil pump, if that is indeed what you did.
Indeed, it's a volume pump, with a relative low pressure.Since, to your point this is not a positive displacement pump, it is my understanding that as a general rule theses pumps do not suck as well as they push.
No valves, so chancing on time is what I do, that's why I added a pressure sensor, so I can see when to change it. I treid to use a filter with a valve, but the pressure of the pump is not able to open it, that's why I don't use it.So, from that I would think (best I can do at this point) that there is potential for the pump to starve or partially starve as the filter does it job and becomes more restrictive. You said in one of your replies that the media filters provide a "huge resistance in the oil flow". So one can assume that as they do their job that restriction increases until the bypass valve, if there is one, opens.
The pump should be in perfect shape, otherwise the flow back is too high.
At the moment I'm designing a pump which will have a higher pressure, and more volume, based on a trochoïde pump like the more modern fours. It's a unit design, pump, filter and sensor. It will give better flow and is more reliable.
For now I have to pump 5W/20 oil, which is too viscose on these type of bikes. If I use 10W or Honda spec 30W the pump doesn't have enough pressure to push these oil through a filter, and even worse when the engine is cold.
I know that the spinner filter isn't perfect and has it's shortcomings in certain rpm ranges, but I am a perfectionist, so I started to make it better, and I achieved a lot, but I'm not there yet. Solving much problems with the low pressure at low temperatures when cold started are time consuming. But it's fun to do so, that's why I'm doing it.
If I wasn't a perfectionist, and not a physics engineer I would never look for an alternative of the spinner filter, because when you change your oil on a regular bases, just as the specialists Bill silver and Ed Moore mention and when you use good oil (really, it isn't that important if this is a synthetic or not) you are always on the safe side.
The only particles which come easy through the spinner filter is aluminium, which is soft and not really harmful as long it doesn't block an oilway. And of course clutch particles, but like I said, when you change your oil on a regular base, you will be all right and a good rebuild engine will probably last longer then many of us ride on it.
For me it's different, I am an engineer, and when something could be made better I will do so,
btw, it's not my intention to offend anyone, so don't feel offende, I don't either. These kind of discussions are razor sharp, because, unfortunately, like I mentioned earlier, not many people back up there theorem's with facts and measurement. I understand that not everyone is capable of doing so, and that makes it even more difficult to discuss it, the arguments are mostly based on experience which can not be "recalculated" by others.
But I do get a little itchy when people "believe" and "assume" that something is working.
