So I removed my left cover to service the clutch and...
Bob750
Post by Bob750 » Fri Oct 12, 2012 4:17 pm
My wife and I bought a CA77 and I think it needs some clutch work. So I opened it up and removed the oil spinner to clean it out while I'm in there and find this... Is this normal?
Edited to swap photos.
Had: '75 CB550 K, '79 CT90
Post by G-Man » Fri Oct 12, 2012 4:19 pm
What?
What?
Bob750
Post by Bob750 » Fri Oct 12, 2012 4:40 pm
Sorry. Had to re-size the image.
Behind/below the oil spinner is this nest of safety wire holding the spring seat pivot bolt in place. I'm concerned about what I might find if I if I remove it. I can get a replacement bolt if the bolt is no good. I'm inclined to leave it alone until I split the cases later.
Thoughts?
Snakeoil
Post by Snakeoil » Fri Oct 12, 2012 4:59 pm
I believe what is shown in the picture is an example of saftey wiring the safety wire that saftey wires the safety wire.
It's known very safe.
regards,
Rob
Bob750
Post by Bob750 » Fri Oct 12, 2012 5:54 pm
Hey! I like safety! I guess I'll leave it like that!
Snakeoil wrote:I believe what is shown in the picture is an example of saftey wiring the safety wire that saftey wires the safety wire.
regards,
Rob
48lesco
Post by 48lesco » Fri Oct 12, 2012 9:58 pm
All seriousness aside... That's just supposed to be an M6 bolt with a washer and spacer. I would untangle that mess and put it together the right way. That part keeps your $200 primary chain from flapping around.
-48
