CA77 Ignition
mason123h
CA77 Ignition
Post by mason123h » Fri Oct 05, 2012 7:06 am
I am currently in the process of trying to get a model CA77 running. I am missing the starter button, so all I have is a hot red and yellow wire that goes to the button, but I don't know how to get it to turn over. I put the key in the ignition position, but all I have is a hot wire and no button. Any suggestions on what I need to connect that wire with to start it?
Thanks for the help!
jleewebb
ground it
Post by jleewebb » Fri Oct 05, 2012 7:27 am
touch it to ground, like the handlebar...
'62 CB77. "It's a rider."
mason123h
Ignition
Post by mason123h » Fri Oct 05, 2012 4:55 pm
I tried grounding the wire and only a weak spark was produced and nothing more. Maybe the battery is too weak.
mason123h
CA77 Ignition
Post by mason123h » Sun Jun 09, 2013 4:51 pm
Still having trouble with ignition. I tried a new battery and tried grounding the yellow/red wire [that is the right wire for starting a CA77 right?] but I am only rewarded with a light spark when I brush the wire to ground. If I just hold the wire to ground nothing happens.
