Check for continuity with ohm meter. (if no continuity clean points)
Turn on key. (12 volts at coil?)
Ground plug.
Open points with finger.
Should have spark. ............lm
styxjr wrote:Ok, everything back together, plugs look ok, but as I turn it over with one of the plugs pulled and grounded to the frame I get no spark. Tried the other plug - same - no spark. I doubt that both plugs are bad? ... so I'm on to paperslammer's points check procedure to see if I can get the light to come on at the F mark on the dyno. I'll be back ...
