Crankcase cover grease fittings...
bellabx
Post by bellabx » Wed Apr 11, 2007 1:05 pm
Are the GREASE FITTINGS, on the drive side crankcase cover of a CL, PRESSED or SCREWED in. If any of you have allready done this replacement, I would appreciate any advice. Thanks
ggray
Post by ggray » Fri Apr 13, 2007 10:06 pm
They're pressed in. Doubtful if you'll get it out without tearing it (the fitting) up though. Ohio Cycle has new ones.
I just bought three...One for the case and two for the swingarm.
Gary
'65 CL77 Owner
ggray
Post by ggray » Fri Apr 13, 2007 10:27 pm
BTW, I removed the one on the case by using a GOOD pair of small vise grips, gripping the thin flange right next to the case itself. Care must be taken though not to gouge the case with the jaws of the grips. You might mask off the case with masking tape prior to trying to remove the fitting. I twisted and pulled at the same time. It came right out. Same method was used on the swingarm pair. Good luck.
Gary
'65 CL77 Owner
bellabx
Post by bellabx » Sat Apr 14, 2007 12:36 pm
Thanks Gary... I used my best vise grips and they came right out. I appreciate the help. Steve
Post by LOUD MOUSE » Sat Apr 14, 2007 5:34 pm
Dp you plan on replacing the zerks?. .........lm
bellabx wrote:Thanks Gary... I used my best vise grips and they came right out. I appreciate the help. Steve
bellabx
Post by bellabx » Sun Apr 15, 2007 8:16 am
l will probably just put the originals back in. They came out clean, and are still in good shape. I just wanted them out of the way while refinishing the side cases.
Steve
66 CL77
