CA77 running rich $$
deadbeathero
Post by deadbeathero » Tue Sep 04, 2012 2:39 pm
Hey everyone, I am slowly restoring my '69 305 Dream. I have
Been working heavily with the carb and I don't have much experience
With restorations. The carb was having an overflow issue but I boiled
it and replaced all the jets and gaskets on te carb. That took care
If that issue, but it is still running really rich. It seems to be taking in to much
Air or gas and it's fowling up the plugs. Any suggestions on what my next step
should be? After every crank I check the plugs and they are black with soot/oil.
deadbeathero
Post by deadbeathero » Tue Sep 04, 2012 8:45 pm
Photo of new plugs after yesterdays crank.
spark by deadbeathero, on Flickr
deadbeathero
Post by deadbeathero » Tue Sep 04, 2012 9:01 pm
Here is a short video of it running right after I had installed the rebuild carb.
side note: I still have yet to ride this bike.
http://www.flickr.com/photos/deadbeathero/7934009774/
brewsky
Post by brewsky » Wed Sep 05, 2012 10:26 am
Soot = too much fuel
Oily = oil leak from rings/valve guides
Soot = powdery deposit
Oily = greasy deposit
Yours looks like too much fuel to me from the pic
What main jet/slow jet/float level are you using?
Stock is 120/35/26.5mm, needle in middle groove, air screw out 1 to 1&1/2
If you got a Keyster kit, the jets are probably too big.
Use the originals if you can, just clean them good.
deadbeathero
Post by deadbeathero » Wed Sep 05, 2012 2:56 pm
I did use a Keyster kit on it. I have the air screw out about 1 1/8 as per
the owners manual. I maybe able to use the original jets so i will try that and let You know! The reason
I replaced everything was because I was having an overflow issue. I have
the float at 26.5mm.
Thanks!!!!
brewsky
Post by brewsky » Thu Sep 06, 2012 7:07 am
The float level should be set with the tab just touching BUT NOT DEPRESSING the small spring loaded plunger that sticks out from the float valve.
Also, make sure the float is not leaking and allowing gas to get inside.
You can submerge it in hot water and look for bubbles. If you see any...it is leaking.
The Keyster kit that I bought for mine came with a 130 main and 40 slow jet......way too rich. The originals should work much better.
deadbeathero
Post by deadbeathero » Fri Sep 07, 2012 4:49 pm
The original jets on my carb were 115/35. It that
acceptable or do I need to get a 120?
