Fixing Cracked Side PanelFixing Cracked Side PanelLeft side panel cracked from vibration. I'm sure this has happened to lots of you. What would you say is the best way to fix it? It feels like it's maybe aluminum. Probably can't JB Weld it, seems like the vibration would snap it apart. What have you guys done or what would you suggest?
thanks.
Re: Fixing Cracked Side PanelYa should find it is steel with a magnet.
I'd buy another one. ...........lm
Easy welding job.....
Find a local guy with Oxy-Acetylene or TiG equipment. Make friends with him and buy him a beer...... 10 minutes with a file / dremel / wet or dry paper and you're done. G '60 C77 '60 C72 '62 C72 Dream '63 CL72
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F You can expect the paint to be burned away y for a couple of inches around the repair. Bargain on sanding and repainting the complete piece.
If you are squeamish about that you are probably better off going the LM route.... :-) G '60 C77 '60 C72 '62 C72 Dream '63 CL72
