Post
by LOUD MOUSE » Fri Mar 02, 2012 4:31 pm
Part #22,25 and 33. ......lm
rzgkane wrote:davomoto wrote:The collar keeps the sprocket off of the seal. There should be a small plate for lack of better word, that keeps the sprocket from traveling outward. it's affixed with a 6mm phillips head screw.
Davo
Collar? What collar? Plate? Hmm, not here. And what does that 6mm screw affix the "plate" to?
I have a crank seal, then a crankshaft starter sprocket, then a starter clutch in that order. The parts diagram shows nothing else, either. You've got me concerned, now, that I don't have all the parts I should have.
Someone was in there before me so what I have might not be all there ever was?
conbs
Post
by conbs » Fri Mar 02, 2012 4:34 pm
I think Davo is referring you to a part with the above name which would be 28116-259-000. Item #22 in my parts diagram.
rzgkane
Post
by rzgkane » Fri Mar 02, 2012 5:42 pm
conbs wrote:I think Davo is referring you to a part with the above name which would be 28116-259-000. Item #22 in my parts diagram.
Ok, the little plate that keeps the sprocket from moving outward I have. Affixed by 6mm bolt. Check.
What I don't see is anything that keeps the crankshaft's starter sprocket from hitting against the crank seal. There was nothing in between these two parts when I disassembled it. My thought is that the sprocket basically sits idle and independent of the starter clutch when not being driven by the starter's sprocket and MAYBE the starter's sprocket being outward of the surface of the crank seal keeps the crank's starter sprocket in line?
Pages from 1960 Dream Parts Manual by rzgkane, on Flickr
Post
by LOUD MOUSE » Fri Mar 02, 2012 5:58 pm
There is Nothing Else. ................lm
rzgkane wrote:conbs wrote:I think Davo is referring you to a part with the above name which would be 28116-259-000. Item #22 in my parts diagram.
Ok, the little plate that keeps the seal from moving outward I have. Affixed by 6mm bolt. Check.
rzgkane
Post
by rzgkane » Fri Mar 02, 2012 6:19 pm
LOUD MOUSE wrote:There is Nothing Else. ................lm
Thank you.
Now if only one of the three sources I've bought crank seals from would get the damn thing to my house we'd be in business.
rzgkane
Post
by rzgkane » Sun Mar 04, 2012 9:46 pm
Crank seal arrived. Chamfered the edge of the case (thanks for that tip) and used 3M Weatherstrip Adhesive around the edge of the seal and it went in very smoothly.
Only hitch was that the seal needs to be counter sunk into the case about 1mm to allow the starter sprocket to also sit inward. Otherwise, the little plate that holds the starter sprocket from traveling outward will mash the sprocket against the seal and hold it from rotating.
